drive showers/BRAVO 1 >
Old 11-10-2002 | 02:01 PM
Default drive showers/BRAVO 1
Have been reading different posts on this subject. If you are not getting the white chalky stuff on your drive, should you still install a drive shower? How do you know if one is necessary. Running a 454 with 500 hp witha Bravo 1. Thanks, 88
88 MACH 1 is offline
Old 11-10-2002 | 02:57 PM
paradigm shift's Avatar
Anything you can do to help keep the drive oil cooler will help it live longer. For the cost of a shower I would install one.
paradigm shift is offline
Old 11-10-2002 | 05:57 PM
88 MACH 1........http://jlbco.hypermart.net/driveshower.htm
enticer is offline
Old 11-10-2002 | 07:08 PM
Dennis Moore
Default Drive shower
We just did an interesting test on drive showers for FAMILY AND PERFORMANCE BOATING MAGAZINE. We had a temp gauge in the drives gear oil. In the first test we had a boat that rode low in the water at high speeds (a cruiser), this prevented the driveshaft housing from running out of the water like it would do on a performance boat. The drive remained deep in the water and was naturally cooled without much effect from the drive shower.
Our next test was on a high performance boat that ran the driveshaft housing out of the water, buy the magazine to see the results of that test. If you have a large boat that doesn't really get up and go it would seem by our test that the water naturally flowing over the driveshaft housing is adequate.
Anybody understand what I just said?
Sincerely
Dennis Moore
Old 11-10-2002 | 09:19 PM
Default Re: Drive shower
Sincerely
Dennis Moore
FAMILY AND PERFORMANCE BOATING MAGAZINE [/B][/QUOTE]
Buy the magazine.
Old 11-11-2002 | 07:25 AM
Yes I get it. Call Rich at Hydro Cool, his product is the nicest around and looks like a stock merc. piece but could be done in any color. He sells thousands of those things, good guy 815-282-6450
HPJunkie is offline
Old 11-11-2002 | 08:39 AM
KAAMA's Avatar
Dennis,
Sure sounds interesting. What issue (month) is the drive shower test in? thanx
KAAMA is offline
Old 11-12-2002 | 09:23 AM
ENTICER???????Is there a price and availability on this setup?
I like the idea just because you can tell if the seawater pump is putting out what it should
OPIE272 is offline
Old 11-12-2002 | 07:37 PM
Dennis Moore
Default Kaama
Don't know yet, the editor hasn't decided.
Dennis
Old 11-12-2002 | 10:45 PM
Run a bottle of Prolong in with the Merc. High Performance lube. Hot Boat did a test on it about 4 years ago and it dropped outdrive temp by 11 degrees! I run a single tube shower and No white what so ever. Better that all the other showers I've seen.
Revd Up is offline
