What crankshaft is this? >
Old 06-06-2020 | 08:33 PM
Default What crankshaft is this?
What crank is this? Out of a 572
chris302 is offline
Old 06-08-2020 | 06:06 AM
Are there any numbers on the front counterweight ?
BillK is offline
Old 06-08-2020 | 07:05 PM
That is on the front counterweight. Some hand stamped numbers 2nd from rear
chris302 is offline
Old 06-08-2020 | 08:11 PM
If the crankshaft was standing straight up on the floor and you looked down on it are there any numbers on the front of the front counterweight ? That is where most manufacturers put their numbers. The number stamped on the edge of the counterweight is probably a balance job number or an engine builders job number. Looks like it has had some holes welded up for balancing.
BillK is offline
Old 06-09-2020 | 11:00 AM
The 8x89 was the only numbers i found i wll look again this weekend when i go to my shop. Thanks
chris302 is offline
Old 06-17-2020 | 09:22 AM
Checked again those are the only numbers on it
chris302 is offline
Old 06-17-2020 | 09:51 AM
Ok,
The forging sort of looks like the GM ones but hard to tell. Also in your one picture it looks like maybe the rod journal has been welded up ? Looked like a pit mark. I wonder if it is something that someone welded up to make a stroker cranks years ago ? I can't post pictures to show what I am talking about, guess you have to be a paying member. If you send me a PM with your e-mail I can e-mail you what I am looking at.
BillK is offline
Old 06-17-2020 | 10:21 AM
F-2 Speedy's Avatar
looks like 2 holes were pluged on the counter weight....what was the bore of the 572 ?
F-2 Speedy is offline
