Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Bottom Repair Northern MD >
Old 06-13-2020 | 08:06 AM
Default Bottom Repair Northern MD
I am looking for someone to repair a 12" X 57" cut out on a 1998 Baja that was cut down to inner fiberglass liner. Will need coring replaced and surface faired before gelcoat. Started as a crack repair and core replacement and was aborted when most of hull was found high in moisture. Not cost effective to recore entire hull so just want it put back together. Anyone close by or recommendations where to take it? Thanks John at 610-299-3598.
boatstogo is offline
Old 06-14-2020 | 07:48 AM
scarabman's Avatar
I would try Lilly Sport Boats or check with Ed (Jr) Trainer at Anchor Marine in Northeast Md. I dont know if Anchor does that kind of work, but Ed is a good guy, and could likely point you in the right direction. Lilly is around the Annapolis area, I believe?
scarabman is offline
Old 06-14-2020 | 08:34 AM
Thank you for your response/
Old 06-15-2020 | 09:02 AM
I give a 2nd for Lilly Sport Boats. They have worked on my last three boats (mechanical and body/paint). Great work and great people.
Awaken is offline
