one drive goes 1/2" lower than the other >
Old 06-20-2020 | 11:00 PM
Default one drive goes 1/2" lower than the other
I have one bravo x drive that trims down 1/2" more than the other, Is there an adjustment somewhere to adjust how far the trim will allow the drive to go?
fcs1965 is offline
Old 06-21-2020 | 12:28 AM
There is a spacer that resembles a celery stick at where the trim cylinder pin passes through the upper unit, the proper position for the spacer on a bravo 1 drive is on the front side of the pin
You may have one of them in the wrong position
JaayTeee is offline
Old 06-21-2020 | 06:41 AM
Both spacers are in front of the pin, an other ideas
fcs1965 is offline
Old 06-21-2020 | 07:09 AM
Depending on if the transom assembly was replaced look for the limit blocks
Could also be a previous version of the cylinders which a bolt and spacer was used
AllDodge is offline
