RE Watrproofing canvas
Old 11-11-2002 | 09:34 AM
jrocket's Avatar
Default RE Watrproofing canvas
Anybody got the best way to accomplish this? Cockpit cover is relativly small and would probably fit industrial washing macine but the storage cover would never. Need to accomplish prior to winter hybernation, any ideas????
jrocket
jrocket is offline
Old 11-11-2002 | 10:32 AM
SUPERSTITIOUS's Avatar
It seems you have 2 questions. If cleaning is the issue, simply scrub the cover on the boat and turn it inside out if the back is soiled. For waterproofing, if you visit the local canvas shops you can purchase waterproofing in a spray bottle or by the gallon and apply with any spraybottle laying around the house and you'll be good to go...
SUPERSTITIOUS is offline
Old 11-11-2002 | 10:37 AM
BoatChic's Avatar
Great Question.
Can the mooring/cocpit cover go in a washer?
I need to clean and waterproof canvas also.
BoatChic is offline
Old 11-11-2002 | 11:15 AM
formula31's Avatar
If you really want to wash it in a machine, use very mild soap and one of those huge tripple washers at the laudromat. Or a nearby hotel, if you can talk them into running it through once. DO NOT USE THE DRYER. It must be put back on the boat to dry. After dry, take the cover off, lay it out on the lawn or someplace clean and spray it. I use Aqua tite. Its expensive ($55 gallon) but works great. Hope this helps.
formula31 is offline
Old 11-11-2002 | 11:31 AM
pachangalpina's Avatar
I friend of mine who worked for Glenn Raven Mills (makes Sunbrella) a few years ago, told me that Thompson's Water Seal works great. The same stuff that you use on your wood decks. Brush it on or spray it on with a spray bottle. It seems to last a few years between applications.
pachangalpina is offline
Old 11-11-2002 | 11:33 AM
Dredgeking's Avatar
my canvas guy told me to paint mine. it seems to be working well and it looks better than it used to.
Dredgeking is offline
Old 11-11-2002 | 12:17 PM
Official OSO boat whore
I sprayed some waterproofing on my old canvas cover. Seemed to work pretty well and last a good two years under mild exposure. The two complaints were: 1. it seemed to attract dirt. 2. The cover shrank and was almost impossible to put on. In fact, we even pulled the windshield frame apart trying to stretch to the snaps.
Cord is offline
Old 11-11-2002 | 04:44 PM
tmager's Avatar
I tried thompson's and it sucked on canvas. I was told to try the stuff at west marine, probably will in the spring.
tmager is offline
Old 11-11-2002 | 06:06 PM
Dredgeking's Avatar
i tell you the silver rustoleum is doing a fine job.
skaterdave
Ft Myers Offshore
5
04-21-2008 07:41 PM
handfulz28
Active Thunder
5
07-26-2007 06:38 AM
CAP071
06-30-2005 11:41 PM
ragtop409
07-18-2004 11:59 PM
Hi-Tech Marine
0
03-21-2004 12:23 PM
