what to use to seal mechanical trim cable through transom >
Old 06-29-2020 | 07:50 PM
Default what to use to seal mechanical trim cable through transom
for those who have replaced your mechanical trim cables, what did you use to seal the transom hole?
fcs1965 is offline
Old 06-30-2020 | 07:53 AM
Wally's Avatar
Were doomed!
Are you asking about what silicone to use or how to finish the outside of the boat off?
If silicone then i would use a fast cure 4200....make sure it says fast cure......the regular stuff takes 7 days to cure!
if your talking about finishing off the outside with some bling then something like a 45* pass through for the cable is usually whats done....or a stainless clam shell cover
-Wally
Wally is offline
Old 06-30-2020 | 09:14 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
We use these - https://www.diamondperformanceparts....roducts/wl-114
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 06-30-2020 | 09:25 AM
fountain put a plastic clam shell on the outside, was wondering if i should use 5200 fast cure or 4200 fast cure to seal the hole and inside the clam shell
fcs1965 is offline
Old 06-30-2020 | 10:32 AM
Ditch fountains clamshell and use what diamond posted. That’s what I did with mine. Seal the fitting to the hull then I push some sealant inside the fitting before tightening. 4200 FC.
Crude Intentions is offline
