Am I leaving HP on the table?? >
Old 07-12-2020 | 09:19 AM
Default Am I leaving HP on the table??
I’m trying to finish a pair of tall deck 615’s ASAP. I bought these cams because initially I was going keep wet exhaust. But the long tails won’t fit this transom without major surgery. Ordering dry tails now and thinking I should rethink the cams. Running dart 325’s with profiler sniper intakes and 1050 dominators.
CR should end up at 9.75
Any ideas would be much appreciated.
hoodoo is offline
Old 07-12-2020 | 10:37 AM
F-2 Speedy's Avatar
Thats not much cam for your cu in and heads........this might be a good choice.....Crane #139651 - 244/256 @.50" with .632/.632, 114
F-2 Speedy is online now
Old 07-12-2020 | 11:59 AM
I was thinking they might not be enough, I’ve had to change direction a couple times, the lockdown in March made getting some parts slow.
My GM bow tie blocks got canceled so I went to Brodix. So now I have gen 4 blocks and gen 6 cams/timing chains. I think gen 6 cams are compatible as long as I have gen 6 timing chains.
hoodoo is offline
Old 07-12-2020 | 12:00 PM
I swapped 741 cams to 651s on 565 NA motors and really woke it up. I would think what Ken suggested above is a great starting place.
endeavor1 is offline
Old 07-12-2020 | 12:29 PM
The cam you posted would be best for a 502-540 ci. I think you need significantly more cam for 615ci.
Griff is offline
Old 07-13-2020 | 06:41 AM
articfriends's Avatar
Way too small, definately go bigger otherwise your mmotor will peak just over 5000 rpms
articfriends is offline
Old 07-13-2020 | 09:10 AM
I have the 651’s on the way.
THANK YOU
hoodoo is offline
Old 07-13-2020 | 09:28 AM
F-2 Speedy's Avatar
THANK YOU
you gonna dyno them ? Id like to see the #'s if you do
Old 07-13-2020 | 12:22 PM
You might want to think about the getting the heads ported. The Dart 325's are a bit small for your combination.
ThisIsLivin is offline
Old 07-13-2020 | 04:29 PM
yes as soon as I get them back
probably mid- late August, I’ll post #’s
hoodoo is offline
