Thermostat crossover >
Old 07-15-2020 | 03:58 PM
Default Thermostat crossover
Hey Guys thinking of installing a
Big Block Chevy Water Inlet Crossover Kit with Bypass
on a 454 7.4 MPI Mag. VI is it really worth it ???
Jamesbajaboss is offline
Old 07-15-2020 | 04:42 PM
Is your stock pump going bad and you have a crossover sitting around or are you going to buy a crossover to replace a perfectly fine water pump?
tmmii is offline
Old 07-15-2020 | 05:34 PM
going to buy a crossover to replace the water pump
Old 07-15-2020 | 05:35 PM
Is the performance worth it
Old 07-15-2020 | 06:28 PM
What's advantage of removing the OEM pump and going crossover setup?
PA.WOODCHUCK is offline
Old 07-15-2020 | 06:51 PM
SABER28's Avatar
id like an answer too. merc has plenty of time invested in research and they use a circ. pump and thermostat. i have mine set up just like merc did and everything works perfectly. why change?
SABER28 is offline
Old 07-15-2020 | 09:08 PM
SB
No performance gain. Just too much cooling headaches for mpi.
spend money on something better, like , but not limited to,strippers or fountain skanks.
SB is offline
Old 07-16-2020 | 08:14 AM
Thank you
Guys
