1997  7.4.  Turns over won't start >
Old 07-15-2020 | 09:12 PM
Default 1997 7.4. Turns over won't start
ok so i have a 97 7.4 merc with a carb. Was running then we stopped for 5 min . when we went to go starboard motor was not running. This has now been 4 wks.Has plenty of fuel and turns over fine , has 50+ for oil pressure when cranking. I change the ICM with the newest revised control module., new cap n rotor, plugs, wires,Coil is good. New pick up module in dist. Dist is turning.motor has compression. Swaped the engine knock ,spark control module from other motor still has no spark. Have power to everything Oh and changed key ignition. Im stump, dont know much a out these Thunderbolt ign. Where do i go from here .
Wellcraft3600 is offline
Old 07-15-2020 | 10:44 PM
it takes three things for a gas engine to run.1,spark at the right time.2,a correct mixture of air&fuel.3,cylinders with compression.find the missing one and correct the problem and it will run.
try disconnecting the tack and see if spark returns.
mike tkach is offline
Old 07-16-2020 | 04:16 AM
Lanyard/kill switch
liberator221 is offline
Old 07-16-2020 | 07:17 AM
Serial number?
carb or MPI
AllDodge is offline
Old 07-16-2020 | 07:34 AM
0k146476. Carb
Old 07-16-2020 | 07:37 AM
Disconnected the tack.. has compression . No kill switch or lanyard.
Old 07-16-2020 | 07:46 AM
SB
SB is offline
Old 07-16-2020 | 09:12 PM
Try pulling the gear selector lever all the way back and give it a try. Neutral safety switch position is finicky.
xlint89 is offline
