New noise in Bravo one. >
Old 07-27-2020 | 06:54 AM
Default New noise in Bravo one.
Just noticed last weekend my B1 outdrive is making noise when placed in gear, forward or reverse. It's best described as a low roar. Silent in neutral. No problem with shifting and no vibration. The mechanic at my local marina thinks I should start with a gimbal bearing but that's turning all the time, in gear or not, Right? The transom unit was replaced 6 years ago so that's the gimbal bearing age.
The drive is 28 years old now with probably 800+ hours on it. Could it be as simple as a gimbal bearing? Would it be possible to even hear a noisy drive bearing while in the water?
NightHawk is offline
Old 07-27-2020 | 07:38 AM
I would remove top cap and inspect gears?
PA.WOODCHUCK is offline
Old 07-27-2020 | 07:49 AM
Drain the oil.
Look for the shine.
liberator221 is offline
Old 07-27-2020 | 07:50 AM
Shiny
Old 07-27-2020 | 08:29 AM
I definitely will be draining the oil this week.
Old 07-27-2020 | 09:28 AM
A bad Gimble Bearing will sound louder when u put the drive in gear,,and it will noisy in the engine bay.
253 is offline
Old 07-27-2020 | 10:08 AM
Several people have told me this also so I'm not convinced it's the drive just yet. Too bad there isn't a zerc on the gimbal ring like the original one had.
Old 07-27-2020 | 03:17 PM
Mystery solved. Drained the fluid. Only been out a few times so far this season and it's burnt, stinking coal black and super thin after changing at the end of last season. Both drain screws have a significant bush of metal shavings. Propshaft clicking loudly when turned by hand.
She's done.
Old 07-27-2020 | 04:00 PM
I would send it to All American Drive Service. Great people and a longer warranty then Merc.
Padraig
Padraig is offline
Old 07-28-2020 | 11:09 AM
George at AADS did mine twice (long story) and I just inspected it after 4 years and still like new with 700hp. Magnets barely have any fuzz on them after 4 years. I also recommend running NEO oil that George sells. Still good and clear after 3 seasons.
ThisIsLivin is offline
