Alarm Issues on 2001, 35 Fountain Lightning w/ twin 500's >
Old 07-27-2020 | 09:24 AM
Default Alarm Issues on 2001, 35 Fountain Lightning w/ twin 500's
Need some input...Having an issue with Alarms on a 2001, 500 EFI. All gauges show great but for no rhyme or reason alarm at the dash sounds, red lights come on and goes into ‘limp’ mode (RPM Reduction). We shut the ignition off, unplugged drive oil level sensors at reservoirs (was told that may be it). Started back up and ran fine multiple times throughout the day. Then end of the day, same issue. I've hooked the Diacom Software to it and neither motor has any stored Codes. The starboard motor did show a General Warning 1 Telltale (see pic below). According to MEFI 4/4B Diagnostic Manual, page 320 states: General Warning 1 = Transmission Overtemp Switch.
Has anyone heard of this?
Thanks for any and all help!
File Type: pdf
cong95 is offline
Old 07-27-2020 | 09:50 AM
F-2 Speedy's Avatar
when does it alarm, going down the lake, at start up ?? do you have tranny's or bravo drives...........unplug the trim level sensor ??
F-2 Speedy is online now
Old 07-27-2020 | 10:14 AM
It alarms after running for a bit (never at startup) and when it does it goes into 'RPM Reduction'. The boat is 100% factory...So, Bravo's. Yes, we have unplugged both trim level sensors and it still occurs. Again, not consistently and has only happened 3 times total over the last two seasons.
cong95 is offline
Old 07-27-2020 | 10:35 AM
F-2 Speedy's Avatar
So disregard the trans over temp because you dont have them, make sure the cannon plug on reach engine is in all the way and secured with a hose clamp, dont you mean the drive lube reservoir sensor, not trim sensor ??
Old 07-27-2020 | 12:11 PM
Indeed, I did mean the drive lube sensors at the reservoirs. Thank you.
cong95 is offline
