Procharger issue >
Procharger issue
Procharger issue
Old 07-27-2020 | 10:24 AM
splashandburn's Avatar
Default Procharger issue
I am having an issue with two Procharger M1SC's. Started this spring on BOTH motors (500 efi's). I am not developing any boost on either motor. I can only run the boat up to 4500 rpm and I'm at zero boost on both gauges. Normally I would start to see some boost at about 4000 rpm and it would run up to approximately 5400 rpm @ 5 psi boost. At idle both before and after the chillers I have good air flow. I have replaced both belts and made sure they're tight. I've run a separate air line to the intake with a remote gauge and still see 0 boost. I'm at a loss as to how this is even possible on both motors. All I changed over the winter was new distributor caps, new plugs and changed the oil in the Prochargers. Anyone have any suggestions of where to start looking?
splashandburn is offline
Old 07-27-2020 | 12:12 PM
Do the Prochargers spin ok by hand? Are the blow off valves stuck open?
ThisIsLivin is offline
Old 07-27-2020 | 01:15 PM
Yes they spin fine by hand. I don't believe there are any blow off valves on these units?
Old 07-27-2020 | 01:30 PM
When turned are the vanes spinning too?
PA.WOODCHUCK is offline
Old 07-27-2020 | 02:41 PM
Wonder if a hose was taken off somewhere during winterization and wasn’t put back on.
tmmii is offline
Old 07-27-2020 | 02:50 PM
GPM
Any chance the keyways are missing in the drive pulleys
GPM is offline
Old 07-27-2020 | 02:57 PM
I haven't checked that but I will. I'm assuming they are bacause at idle its definitely pushing air thru the intercoolers
Old 07-27-2020 | 02:58 PM
There is only one discharge coming off the Procharger going into the intercooler. No other hoses.
Old 07-27-2020 | 03:00 PM
I pulled the pullets off and checked the keyways and they were fine.
Old 07-27-2020 | 03:13 PM
you should have other hoses on the engine that’s someone could have off off to fog instead of putting 2 cycle oil in the water separator. If they forgot to put those back on you would have a boost leak.
tmmii is offline
