Livorsi High-Flow Fuel Filter/Water Separator Bracket
Administrators
Introducing the NEW High-Flow Filter/Water Separator, specifically compatible with Mercury's 450R Outboard and many other high horsepower engines. This bracket can be mounted almost anywhere with its' multiple port locations. The configurable mounting bracket allows the fuel filter/water separator bracket to be mounted in very tight locations and is available in single, dual, and triple- tank configurations. The 10 different color options allow the separator to easily match whatever style you have going on in your boat. Private labeling also available for the brackets.
The High-Flow Fuel Filter/Water Separator Bracket is anodized and powder-coated for complete saltwater protection. 1/2" or 3/8" NPT fittings are available and purchased separately.
For tighter spaces and to save space, mount this Fuel/Water Separator in the "down" position. This filter can be purchased with sight glass and drain.
center.
For more information please call Livorsi at 847.752.2700 or email [email protected].
center.
