Fountain Fever 27 Performance
Hi, I’m looking for opinions on how well a Fountain Fever 27 does on rough water? I currently have a Donzi Classic Blackhawk 22, so I’m used to descent rough water performance. Is the Fountain better by a little, substantially better or worse than the Blackhawk?
I would appreciate hearing some opinions.
thank you
thank you
Jim Valeko out of Grand Rapids had a 27 that ran really strong. The boat was named "Heads Up' as he is a cylinder head specialist. If you can track him down, he had the fastest one that I have ever seen and ran it out of Grand Haven a lot.
Joe
Joe
I've driven both hulls. The Donzi 22 is the softest riding 22 on the planet in my humble opinion. The 27 Fountain - and many folks will call it a 25' - rides ok, but it was not one of Reggie's better designs. (The 29' Fountain with the same power is actually faster and more capable in rough water.) The cabin on the 27 is ridiculous, but it's a hell of a lot bigger than what you have on the 22 Donzi - which has nothing. The Fountain is a bit of a handful with anything more than stock power, but the 22 Donzi has some unique handling traits too - as documented in Powerboat magazine. (They tend to fall off the inside chine in sharp, low speed turns.) While I've personally experienced this in a Donzi, I've never experienced anything weird in a 27' Fountain.
As for which one takes rough water better, the Fountain is a bit heavier and a bit longer, has more freeboard, but a bit wider in beam. Believe it or not, I'd call this one close to a draw, but the Fountain will feel a bit safer.
I had a 27 fever with a 496 mag ho. Great boat and ran well. Also had a Blackhawk 22. I have a standard 22 classic now. It fits in my garage. Love the boat. The fountain ran 72 gps. A great built boat. I felt it had a higher finish level over Donzi. A 27zr would be close. The 27 fever has a smaller fuel tank. I think 50 gallons or so.
[QUOTE=thirdchildhood;4751051]As a fellow Donzi 22 Classic owner and your neighbor, I'm sure the Fountain will handle rough water better but it won't be as fast. If it were me I'd try to find a Donzi 27 ZR with a 525. 🙂[/QUOTE
Duplicate, can’t delete!
