Idle Map STR fault >
Idle Map STR fault
Idle Map STR fault
Old 08-03-2020 | 08:54 AM
Default Idle Map STR fault
I keep getting this Idle Map STR fault on my smartcraft monitor for my starboard 600 SCI. My Rhinda isn't picking up any codes. I replaced the MAP sensor, but I'm still getting the error. When the boat is cold no error. As it gets warm, I will get the error. What am I missing here. Is there another MAP sensor other than the one on the side of the intake?
endeavour32 is offline
Old 08-03-2020 | 09:06 AM
F-2 Speedy's Avatar
You referring to the MAT sensor ? manifold absolute temp, kind of sounds like your symptoms
F-2 Speedy is offline
Old 08-03-2020 | 10:50 AM
Nope, the code is IDLE MAP STR. Here is a picture. Once the fault is triggered, my RPMs increase about 100 RPMs and it will run rich.
Old 08-03-2020 | 12:31 PM
SB
Idle RPM MAP Strategy (same as MAP Idle Check)
Map Idle Check. MAP Sensor Rationality/Loss of Vacuum Check (Not Available On All Models)
SB is offline
Old 08-03-2020 | 12:57 PM
SB, what would a dumb person be looking for, or what do I need to check?
Old 08-03-2020 | 03:18 PM
SB
I'm dumber than the rock I'm sitting on taking a break right now.
WHat was the map sensor part # you used ? Got a pic ?
I only see one MAP. There are two intake air temps. Before and after.
SB is offline
Old 08-03-2020 | 05:16 PM
Bought the part new. It is part number 8M6000628. As far as I can tell, there is only one MAP sensor, but I have been known to be wrong once or twice. I have a diagnostic manual but that was little help. So I have now ordered a service manual, maybe that will be more informative.
Old 08-03-2020 | 07:45 PM
Mine throws that fault once in a while when I first put it in gear after idling a bit when it's hot.
I think it that the IAC can't react quick enough at times to supply enough idle air..
If I touch the throttle just a bit right after I put it in gear it works just fine...
Boatally Insane is offline
Old 08-03-2020 | 07:47 PM
Originally Posted by Boatally Insane
Mine throws that once in a while when I first put it in gear after idling a bit when it's hot. I think it that the IAC can't react quick enough at times to supply enough idle air..
Mine won't stop beeping once it starts. Do you have to restart or will it self correct and then stop beeping.
Old 08-03-2020 | 08:23 PM
I have to shut it off and re-start the engine to get it to quit beeping as well
Mark Boos tuned mine.. I sent him an email asking about it, but haven't heard back..
