Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
502 mag mpi running lean >
Old 08-04-2020 | 10:06 PM
Default 502 mag mpi running lean
Hey guys I got a friend with a 1997 fountain 27 fever with a 502 mag mpi. He just upgraded from stock manifolds to Gil headers. Since he's put the headers on he has been running lean. He got a tune from Arizona speed for headers and still running dangerously lean (plugs white). Was wondering what is making it lean even after the new tune from Arizona speed. He's checked everything in the fuel system.
Fountain525 is offline
Old 08-04-2020 | 10:34 PM
SB
What are you using for plugs ? Some are real hard to read.
i worked on a 96 502mpi , from brand new that added gils after a few years otherwise stock motor that did not ‘go lean.’
SB is offline
Old 08-05-2020 | 04:14 AM
Not doubting you, but wouldn’t vac hose being off regulator make engine rich all times except under load and then be in range?
liberator221 is offline
Old 08-05-2020 | 06:00 AM
SB
You are totally right. More psi = richer. 3 hrs sleep yesterday and apparently some Sometimers. Lol. . Will edit.
What plugs are you trying to read and how old are they ?
SB is offline
Old 08-05-2020 | 07:22 AM
Might be the tune, agree headers won't cause it to go lean
Without AFR readings would be good to see some data from the sensors.
Happen to know if the fuel pressure is at 37 psi for VST?
Is MAP (Pin-J1-9) voltage at 4.9V with ignition ON, and what is it running (around 1.5V)?
AllDodge is offline
Old 08-05-2020 | 08:01 AM
He is using NGK bpr6es. I believe these are the recommended plugs from Mercury.
After adding Gil's you didn't need a tune?
Old 08-05-2020 | 08:39 AM
F-2 Speedy's Avatar
thats a pretty hot plug
F-2 Speedy is offline
Old 08-05-2020 | 09:04 AM
Is he using ethanol free fuel? Stock tune is fine. Good luck!!!
PARASAIL941 is offline
Old 08-05-2020 | 09:17 AM
SB
Do these engines have aftermarket heads ?
The BPR6ES have a .750 reach and are gasketed, which many aftermarket heads use.
The factory 502mpi uses .460 reach plugs with tapered seat (no gasket)
Fsctory plug MR43T. Many people use R43TS. Which is projected tip version. Not available in Marine (M).
The Gills are far from a tuned header. Ther are not a header either. They are just slightly better than stock manifolds on a NA engine. Much less weight though. 80+lbs lighter.
SB is offline
Old 08-05-2020 | 10:09 AM
Factory plugs are
AC - MR43T
Champion - RV15YC4
NGK - BR6FS
AllDodge is offline
