Go Back  Offshoreonly.com > Owners Forum > Ilmor High Performance Marine
How to change coolant on 625 >
Old 08-07-2020 | 06:10 AM
Default How to change coolant on 625
I just purchased a 2006 DCB F29 with twin 625’s and I really like the Ilmor engines. I am trying to get all the maintainence items up to date. I don’t have a manual and I am not sure how to best get all the fluid out. I’m not sure how many people still look at this thread. It’s a shame they are not making the 10’s anymore. Thanks
SkiDoc is offline
Old 08-07-2020 | 10:03 AM
Sydwayz's Avatar
Forum Regulator
There is likely a plug on the block, somewhere down above the oil pan, and probably one on each side.
Sydwayz is offline
Old 08-07-2020 | 10:15 PM
Probably not a ton of help in changing the coolant, but here’s a manual you may find helpful.
https://www.manualslib.com/manual/89...mor-Mv-10.html
ToMorrow44 is offline
Old 08-08-2020 | 06:29 AM
Thanks for replies. The manual does say how to properly fill but doesn’t really say how to drain engine. Like sydwayx said there has to be block drains. I think probably mine have never been done.
SkiDoc is offline
Old 08-08-2020 | 06:37 AM
Which F29 did you buy?
Old 08-09-2020 | 06:09 AM
This one and I love it. Best handling cat I have owned.
SkiDoc is offline
Old 08-09-2020 | 06:26 AM
very nice. Yeah, I don’t think I’ve ever heard anything bad about an F29.
Old 10-26-2020 | 06:02 AM
None of the manuals cover draining the antifreeze. I gave Ilmor a call and they said there were no drains and to pull the lower coolant hose. I did this and a lot of coolant came out. I don’t know if all came out or not but it must have been most of it. I also pulled the end cap and verified everything looked good. Before you pull the end caps off the coolers order some 4” Sek-dure gaskets. It was a good thing to do this as I found broken off impeller vanes in the lower cooler of 1 of the engines. On my engines there is a purge fitting on the thermostat housing to make sure you get all the air out of the system.
SkiDoc is offline
Old 10-26-2020 | 06:18 AM
Thanks for the update.
Eddienel is offline
