Electric fuel shut off >
Old 08-11-2020 | 04:10 PM
Default Electric fuel shut off
Since my repower I've been running without the antisiphon valve. Don't want any resistance to flow using the cool fuel pump.
For safety I need either that or electric fuel shut off, so leaning that way. Could wire direct or use a relay.
Anyone using them?
AllDodge is offline
Old 08-14-2020 | 07:02 PM
Ayuh,...... It's a pretty simple process usin' an oil pressure switch, like Merc does it,.....
Bondo is offline
Old 08-15-2020 | 06:58 AM
I wouldn't use an oil pressure switch, would have it turn on/off by the key.
AllDodge is offline
Old 08-15-2020 | 07:30 AM
keys get left on.........tiara yachts any many bigger others use electric valves
boostbros is offline
Old 08-15-2020 | 08:27 AM
SB
Sea Rays use electric fuel valves instead of anti siphon, also.
I have no experience with these.
SB is offline
Old 08-15-2020 | 09:09 AM
Agree keys get left on, but if its left on then its the same as I have now with no antisiphon valve
The how to is simple, just wonder if others have done it
AllDodge is offline
Old 08-15-2020 | 11:42 AM
If your still using EFI then wire it to that pump with a rely.
PA.WOODCHUCK is offline
Old 08-15-2020 | 11:45 AM
That's a good spot
AllDodge is offline
