Is there any reason I can't sub right stuf for a gasket on trs drives? >
Old 08-24-2020 | 02:45 PM
Default Is there any reason I can't sub right stuf for a gasket on trs drives?
I'm in the process of upgrading my transmissions to 72c. Actually, at the install point after fabbning new mounts. It was super tight getting the 454s out of my 30' panther before, and I know I have to pull the drives for reinstall. So I just got the first one off and noticed a torn up gasket as it came apart. I dont really feel like making 2 if I dont have to, I was thinking of using the Right Stuff from permatex. I've had awesome luck with this stuff on a lot of engines I've bnuilt, and I cant really see a reason not to use it instead of making a gasket. I figured I'd ask more knowledgeable people before I go ahead. The gasket im refering to is where the trs bolts to I believe the gimble? I
thisd is what im referiung to
https://www.permatex.com/our-brands/the-right-stuff/
airbats801 is offline
Old 08-24-2020 | 04:15 PM
BDiggity's Avatar
You could just buy replacement gaskets.
https://www.perfprotech.com/gasket-s.../product/99717
The gimbal to transom is
https://www.perfprotech.com/gasket-5...product/100051
BDiggity is offline
Old 08-24-2020 | 06:26 PM
Craney's Avatar
The drive doesn’t have to be removed to pull the motors or to install the motors.
Craney is online now
Old 08-25-2020 | 03:24 AM
I barely got the engines out with the old 71 transmissions. With the 72c, I dont I dont see them going back in without pulling the drives. You may have much more space then me.
As for buying gaskets, why are you spewing bull****. I already said I can make the gasket. I dont need you wasting space telling me to buy a gasket. I see no reason to even make one these day personally these days unelss it has to do with a clearance issue. I'll just do it and let anyone in the future know how it works out.
Old 08-25-2020 | 03:52 AM
Craney's Avatar
Your pulling the engines and transmission together right?
Old 08-25-2020 | 04:54 AM
'll spew some b ll chit . since gaskets are available why half ass it.........JMO
motor is offline
Old 08-25-2020 | 07:14 AM
You can do whatever you want, I’m sure it would work, but typically where a gasket is used and available... a gasket is used.
Liquid gasket is like a last minute, last resort backyard mechanic, kinda thing.
If I’m looking at something and I see rtv in all the wrong places it’s a huge red flag to pass on whatever it is.
M1boater is offline
Old 08-25-2020 | 08:37 AM
BDiggity's Avatar
sorry i didnt realize airbats was short for airbatstein. sounds like you are doing a lot of other work, seems like you have the time & money to cough up $20 for the proper gaskets.
BDiggity is offline
