pair of 990 heads or single 088 head - mkIV >
Old 08-27-2020 | 10:30 AM
Default pair of 990 heads or single 088 head - mkIV
recently purchased a pair of engines and come to find out one of them has a set of mismatched heads. One side has a Gen V 088 w/ 2.19 intake valves and the other has a Gen 6 2934 w/ 2.25 valves. There are a couple different ways I could go but ideally looking for a pair of stock 990/188 rec port heads to match the other engine. I could also make use with a single genV 088 head if needed. Closer to Michigan the better otherwise will need to ship.
Let me know what you have!
Thanks!
-Jim
JimNut is offline
Old 08-27-2020 | 12:30 PM
I have new and used 088 heads
Call me Ron Sporl 504-616-6005
Sporl Performance is offline
Old 08-27-2020 | 01:38 PM
I'm really hoping for a set of 990s but if I don't ill definitely keep you in mind!
JimNut is offline
Old 08-27-2020 | 03:15 PM
Have one new 990 also
Old 08-27-2020 | 04:04 PM
There is a single 990 on ebay, shows he is in Ft Lauderdale for $500
https://www.ebay.com/itm/BBC-454-Cyl...5.c20#viTabs_0
AllDodge is offline
Old 09-11-2020 | 06:54 AM
Default 990 heads.
I have both a set of mildly ported 990 heads aNd I have a set of stock 990 heads but only one head is good. Other has small crack. Id sell either the good Ported set or just one of the Stock heads if u only need one. Let me know
nbaker103 is offline
