Mechanic/Shop Needed
Recently came in position of a Hustler Sling Shot need a good shop to go through and get ready for 2021. I live in Falmouth but would drive if needed any recommendations on a good local shop that wants work ? Power is 540 w whipples drives are XR with sport master lowers.
thank you in advance for the recommendation
Thank you
that would be great the boat has been neglected for sometime for starters the port motor does not run properly that needs to be fixed go through drives go through starboard motor test or replace cmi headers trim pumps are not functioning proper would like some gel coat and clear coat repaired basically I would be considering somewhat a restoration. Are you guys busy now maybe I could give a call Tuesday to set something.
Thank you
Thank you
Outerlimits has been amazing to deal with Jason and Dan there are top notch even though my boat is only in for repairs at a fraction of the cost of what others spend there I have been treated the same. Not only there attention to detail in there work but there expertise in advise I have never been given this level of service from any other business I have worked with. I would recommend them for all your needs you wont go wrong I will be a customer for life and hope to move up into the Outerlimits brand in the near future. Support Local Business ! Thanks Outerlimits
