Mystery oil leak. 502 mag MPI. PICS
502 mag MPI has a mystery oil left on the rear port side of the engine. (Right side if you’re looking at it). It’s running off the bottom of the manifold. Valve cover seems to be tight. Looking for some thought before I tear into it. You can see in the photo where it’s wet in the manifold
I had one of those oil lines look good too but it was in fact the leak. It was near the fitting that is crimped onto the hose.
