525/500efi accessory brackets,pulleys >
Old 09-18-2020 | 05:41 AM
Default 525/500efi accessory brackets,pulleys
Looking for 2 sets of 525 or 500efi accessories, brackets and pulleys.
lucky cat is offline
Old 09-18-2020 | 07:39 AM
F-2 Speedy's Avatar
I might have 2 525 crank pulleys, I'll check
F-2 Speedy is offline
Old 09-18-2020 | 08:55 AM
FYI, there is a difference in diameter and offset on the water circulation pump pulley on these two engines.
endeavor1 is offline
Old 09-18-2020 | 09:17 AM
F-2 Speedy's Avatar
Chris is correct, and crank pulley's because the 525 has crank trigger wheel, and I think the PS pulley is also different .........OP you need to pick 500 or 525 and stay with that for everything is what Id do
Old 09-18-2020 | 09:25 AM
Will do...thanks
Old 09-20-2020 | 02:18 PM
I went thru this a couple years ago for 500 efi's..... very hard to find. I was able to get what i needed from MarineEngine.com and ebay.
Got Cigs is offline
Old 09-24-2020 | 02:40 PM
looks like the pulleys and brackets are all discontinued for both 500efi and 525..😞
Old 09-24-2020 | 02:53 PM
F-2 Speedy's Avatar
Call some of the engine builders, most are not on here, Ill sell the 2 crank pulleys to get ya started
Old 09-24-2020 | 03:17 PM
Sounds good, thanks Speedy... can you text me at +16162931106
Old 09-24-2020 | 04:03 PM
F-2 Speedy's Avatar
