2006 496 Mag HO engine runs sluggish and runs rough when engine is cold >
Old 09-24-2020 | 07:32 AM
Default 2006 496 Mag HO engine runs sluggish and runs rough when engine is cold
Hi I have been experiencing an engine issue with my 2006 496 Mag HO, it's running rough & sluggish when the engine is cold and it's the first time getting on plane for the day. I live in the Detroit Metro area of Michigan and since the weather & water have cooled down my engine is running rough & sluggish when I first get on the throttle to get on plane, the engine makes strange exhaust sound from the starboard side and sounds like it's missing/ like a choke is stuck on for about 40-60 seconds and then it fully clears up and is fine for the entire rest of the day. The engine idles fine, tach reading is good at idle not bouncing around, and has never stalled out. I can feel and hear something change and the engine fully smooths out and has full power after 45- 60 seconds it's almost like it shifts into 2nd gear. I get No alarms, beeps, nothing indicating an issue. Any ideas and thoughts on what could be causing this to happen?
h20guy is offline
Old 03-01-2021 | 05:57 PM
Hi, did you ever find out what was causing your rough running issue on a cold engine. I have the same issue to a T on a 2005 496 Mag. Sounds like it has dead cylinders on the first take off and then its fine rest of the day. If the engine cools allot like a take a long lunch break it may lightly do it but its very strange. I've had the boat 10 years and it never did this before no matter if it was middle of winter. Boat lives in lake Havasu, AZ.
nanzpac01 is offline
