Thunderbolt iv ignition sensor ground wire connection point.
Replacing a 28 year old Thunderbolt IV ignition sensor assembly that was 2-wire + a 3rd ground wire that was connected between the bottom of the sensor mounting screw and the TB iv module bracket mounting bolt (@ the exhaust manifold)...The module’s ground wire was also connected to the same bolt.
The instructions for the new ignition sensor says to ground the new 3rd wire at the main flywheel ground point which is not doable without fork lifting the engine cover off. IS THE BRACKET MOUNTING POINT ON THE EXHAUST MANIFOLD AN APPROPRIATE GROUND SPOT?
I understand a bit better now. It should be fine there. Your first description made me think you had a bracket coming off the bolts that go into the head. Any secure clean spot that is metal on metal to the block should be fine for that ground.
i have the same cobalt hull the engine hatch is also the rear bench seat making it hard to access the back of engine i pull the hatch pin and block the hatch straight up i also switched it to the delco est dist it runs and idles better...the est,s idle with a lot of inital timing making a big block smooth
...yep I lift the heavy SOB and prop it straight up...I suppose it would be easier if I also removed the 2 bulkheads/walls that wreck my laying down room. I feel for boat mechanics, for sure. Thanks for the help.
