Stainless marine exhaust pipe plugs >
Old 10-10-2020 | 10:43 PM
Default Stainless marine exhaust pipe plugs
Best place to get the plugs needed to replace one of these elbows
87MagnumII is offline
Old 10-11-2020 | 10:46 AM
Try Jerry @ Stainless, the plugs you need have Anodes on them to help with electrolysis.
GLENAMY 242SS is offline
Old 10-11-2020 | 12:39 PM
Brass pipe plug from the hardware store
Griff is offline
Old 10-11-2020 | 03:56 PM
You have Aluminum manifolds bolted to iron heads and stainless risers, I personally would go with the ones with anodes. Your boat, your money.
Old 10-11-2020 | 05:27 PM
Agree, local hardware store
No issue with Aluminum to Brass (elbow)
No issue with Stainless to Aluminum (also has gasket)
Is an issue with Cast iron to Aluminum but there is a gasket between the two
AllDodge is offline
Old 10-12-2020 | 07:36 PM
Like Griff said , I use a brass plug , or you wanna get fancy get a 3/4" anode and cut the anode short if it`s salt water .. I did that too and on my intercoolers
ICDEDPPL is offline
Old 10-13-2020 | 12:08 AM
He's replacing a regular 90* brass fitting, so I don't any issue using a regular brass pipe plug.
Griff is offline
Old 10-13-2020 | 08:15 AM
mcmaster carr is a good source for hardware.
mike tkach is offline
