brake job
Old 10-12-2020 | 09:49 AM
Default brake job
So the formula 280ss (~10k) trailer needs a brake job/upgrade/re-do along with lighting redo.it is a tri axle with surge drum on 2 axle's. Just picked the boat up this summer so the condition is a little unknow but the surge brakes do not work at all. cost is approx. the same do I go all 3 axles full electric or run EOH drum on just 2 axles.... it is a fresh water boat only so full electric doesn't concern me. the Baja has EOH disk on all 3 axles and its great, but I'm not spending the money on this boat/trailer to go that route. I have a 9 mile short slow tow to the lake every weekend with maybe 1 or 2 tows a season that is maybe 3 hours and I'm thinking this is a 3-5 year boat before it goes down the road.... but still need/want brakes that function when I need them....
30outlaw is offline
Old 10-12-2020 | 10:16 AM
Boat weight 6300
Cheapest route, replace master cylinder and brake parts
Being fresh water - go full electric which requires welding up the hitch so it doesn't move. (this is what I did to my other trailer, and bought new trailer later with same) 10K boat
AllDodge is offline
Old 10-12-2020 | 11:21 AM
Originally Posted by AllDodge
Boat weight 6300
Cheapest route, replace master cylinder and brake parts.
for a single 7300 for twin plus I assumed 2k for trailer.... minor in reality
yeah cheapest but I cant stand surge brakes, want to upgrade away from them at minimum.
I am/have been leaning this way, being a 2003 trailer I assume not much is going to be good or reusable on the current parts. , just don't want to be disappointed after the work is done...
30outlaw is offline
Old 10-12-2020 | 06:19 PM
Just do electric brakes on the same two axles. If surge will stop you on two axles, so will electric. You are only going 9 miles a whack. How bad are the drums? If good, just new electric complete backing plates, controller, wiring, weld the coupler or buy new and call it a day. Shouldn't be more than $500 total. Easy one day install taking your time.
Forgot -- Also a breakaway kit, but still under $500 total.
shunter2005 is offline
Old 10-13-2020 | 06:23 AM
Active Streak: 30 Days
etrailer.com. I re-braked my cargo trailer last year. I upgraded from manually adjustable to auto adjust, new battery box and all the parts were factory parts (Dexter Axles) in sealed boxes.
Helmwurst is offline
