Comp Camshafts 2 New, 2 used >
Old 10-13-2020 | 09:11 PM
Rookie's Avatar
Default Comp Camshafts 2 New, 2 used
2 brand new HR camshafts ($800/pair) customer changing direction and 2 used HR camshafts ($200/each) + shipping. All 4 are billet MKIV cams with fuel pump boss The 2 used cams are still in engine should be out soon. (will update pics then, they look good)
New cams
Used Cam
Rookie is offline
Old 10-14-2020 | 09:06 AM
Can't see the pics. Can you text me the specs on the used cams? 505 3three1 5five76
89Force235 is offline
Old 10-29-2020 | 10:06 PM
Rookie's Avatar
TTT open to offers
Rookie is offline
Old 10-31-2020 | 02:49 PM
These would be a nice upgrade from the normal 741 cam I would think. What were they spec’d out for? Build - CI - RPM
Good luck with sale!
getrdunn is offline
Old 10-31-2020 | 04:46 PM
Default Cams
What engine these for i have a stock 454 365hp looking to upgrade
Baja 250es is offline
Old 10-31-2020 | 08:38 PM
Rookie's Avatar
I'd use the 236/236 used cams in a mild 454 build. I just built a pair of ~450HP 454's with similar cams.
Rookie is offline
Old 11-08-2020 | 08:47 PM
Rookie's Avatar
1 used cam sold. 1 used and 2 new left.
Rookie is offline
Old 12-31-2020 | 07:52 PM
Rookie's Avatar
2- 239°/245° new $350 each, 1- 232°/232° used $150
Rookie is offline
Old 12-31-2020 | 08:04 PM
Default Cam
Would this be good in a blower application 454
Old 12-31-2020 | 08:27 PM
Rookie's Avatar
I think it would work good in a 454 blower New cam. 250 or 6-71 application. Which cam are you inquiring about?
Rookie is offline
