Go Back  Offshoreonly.com > Technical > Electronics
In search for ICM for 1984 Mercruiser 260 (350 ci) >
Old 10-26-2020 | 09:08 PM
Default In search for ICM for 1984 Mercruiser 260 (350 ci)
Will a “V8-24” ICM work or do I need a “V-8-22”
Pkruppert is offline
Old 11-05-2020 | 11:03 AM
TomZ's Avatar
It more than likely came with the 24. That seems to be the most common. The 22 was used on some 5.0/5.7 engines.
The 24 stops advancing timing at 3750 RPM or close to there. The 22 advances the timing through 4500 RPM.
TomZ is offline
Old 11-05-2020 | 01:19 PM
The 24 will work fine.
Griff is offline
Old 11-05-2020 | 06:44 PM
use the V-6 modual set the top end timing and the high idle timing will run very smooth i think they advance 14
boostbros is offline
Old 11-06-2020 | 01:12 AM
No reason to use a V6 module on a stock 350. A V6 module only gives about 10* of advance on a V8 engine and its at full advance at 1800ish rpms.
Griff is offline
Old 11-06-2020 | 06:54 AM
I believe I have a V-8-22 Ignition module if you need it.
Ryanw10 is offline
