Powerplay 28 single for sale >
Old 11-23-2020 | 05:28 PM
Default Powerplay 28 single for sale
single 28 for sale needs power motor is out selling without motor 20k firm
Walls is offline
Old 11-24-2020 | 08:47 PM
Any bilge pics? transom good?
open87 is offline
Old 11-26-2020 | 10:38 AM
Someone better jump on this. (NOT SAYING IT DOES, JUST SAYING)
even if it needed a couple grand in misc hoses, nuts, bolts, etc worth of freshening up plus the engine & exhaust
you'd be miles ahead in a build.
What is it mid late 90's ? vacumm bagged first rate layup, rigging & wiring that puts nasa to shame
Powerplay Boats
outonsafari is offline
Old 11-26-2020 | 11:59 AM
Craney's Avatar
I know I keep thinking about it,but that purple interior is killing it for me that’s a lot of purple.
Craney is offline
Old 11-26-2020 | 12:01 PM
Craney's Avatar
How much Hp do you think you need to get in the low 70s?
Craney is offline
Old 11-26-2020 | 12:27 PM
Powerplay Boats
Yes it’s a 97 vacuum bagged. Top quality boat
Walls is offline
Old 11-26-2020 | 01:46 PM
It's a Powerplay, purple is part of it.
floatingphil is offline
Old 11-26-2020 | 02:00 PM
betcha a 525 would would make it a real runner,
as an example my 26 x 8'2" weighs in at 3780 ready to go in the water minus fuel.
full tank 65 gallons 25 m plus gets me a tick over 73 gps reliably in flat or negligble chop @ 5150
w/ a best ever 76.4 in perfectly set up 2 foot chop testing a 27 m plus.
flat or negligble chop the 27 gets me a tick over 74 at 4900.
edit in 496 mag ho stock engine w/ +6" cmi's and cleaned up water and oil plumbing.
so if the hull weight of the powerplay is as advertised, fully rigged at or under 4000 pounds betcha you could get used to the purple.
if your single just tell the chicks it was princes' boat and you bought it from estate.
Makes sense to me but what do i know, could be way off, ask seller power and speed.
im open till 1800 and will search offshore c/w that hull out of curiosity.
Old 11-26-2020 | 02:12 PM
At 2,350 approx weight I’d guess a 502 mag would cut it. Lol...
Actually weight I’d say 650 plus. Just a guess.
Awesome rough water boat regardless.
getrdunn is offline
Old 11-26-2020 | 08:34 PM
Seems about right. From what I heard, this one went 78-80 with 725hp. With stock hp500 it will do 67 ish.
And yes a ton of fun in the waves!
Deanrw3 is offline
