HP 500 Blue Paint >
HP 500 Blue Paint
HP 500 Blue Paint
Old 12-29-2020 | 02:05 PM
Default HP 500 Blue Paint
So I am refreshing both my engines,, I need an exact color match for HP 500 Blue paint,,does anyone have a paint code they have actually used that is right on to match the Merc. Blue.
This has been discussed many times,,I would like an exact color match if possible.
253 is offline
Old 12-29-2020 | 02:26 PM
Just a thought. Take a chip to your local automotive paint supply. They can put it in a scanner and give you an exact color match. Most can even put it in spray cans for you.
Smitty275 is offline
Old 12-29-2020 | 02:41 PM
Thanks Smitty,, I may need to do just that.
253 is offline
Old 12-29-2020 | 03:47 PM
F-2 Speedy's Avatar
there's probably 20 threads on here about merc blue paint, use the search button
F-2 Speedy is offline
Old 12-29-2020 | 03:51 PM
bencini231's Avatar
I found these in a old thread.
The dupont b8110a (old stock#) = DPC# 15663 (Color Perm Code AJ935) This color is found on Chevrolet 1981 (paint code 20) and Pontiac 1981 (paint code 7204) the name of the color is BRT BLUE.
this is to mix 48 oz imron (2 qts) of the Chevrolet 1981 paint code 20
531U LS BLACK 40.6
521U ALUM 100.3
565U RED 357.9
559U BLUE 731.2
572U CLEAR 1053.8
570U LO VOC BINDER 1381.9
8585S REDUCER 1409.0
bencini231 is offline
Old 12-30-2020 | 09:31 AM
Thanks, I will try this since I cannot find any spray cans
253 is offline
Old 12-30-2020 | 09:41 AM
Rookie's Avatar
Go to an automotive paint supplier and have them mix it up for you. Then put it in a spray jar from your local hardware or box store.
https://www.offshoreonly.com/forums/...ng-engine.html
Rookie is offline
Old 12-30-2020 | 09:48 AM
Hey Mike, I found the GM code 20 paint at the advance auto parts store in evansville in a spray can when i did someone's engine
snapmorgan is offline
Old 12-30-2020 | 10:02 AM
Thanks Joe I'll check on that.
253 is offline
Old 12-30-2020 | 11:23 AM
I had some of the b8110a mixed up and wasn’t 100% satisfied as it just didn’t seem to be the same but I didn’t have an exact side to side comparison. Next batch I had them add a touch more silver in the mix and turned out great. It at least looked much closer the merc blue powder coat I was using on same project.
getrdunn is offline
