Bbc 509 procharger D1?
Bbc 509cid, 9.6 static comp. 050" 230/236, 0.650"/620" Lift, 112lsa roller cam. Iron heads. How much boost I could use? Procharger D1. I was thinking 4psi max, that should make Well over 600hp from 500hp NA base engine.
Sounds too good to be True. Ring end gaps and piston to wall clearances are allready In specs for boost. Only concern is ferrea 5000 series valves, maybe fine for mild boost with good tune @ dyno. 7psi would put over 700hp.
