06 Lightening Transom and Stringer Rot? >
Old 01-14-2021 | 09:05 AM
Default 06 Lightening Transom and Stringer Rot?
I am down here in Texas as we speak looking at a 06 38 Lightening and just wanted to get some input on the transom and stringer situation on these boats. Was this particular year a problem one? I will only be here for 1 more day , any help would be greatly appreciated! Bilge is filthy and has some water in it. Doesn't look like has been very well cared for. Kinda sucks because engines/drives and hrs. are great. Boat runs and drives perfect, just needs some cleaning up!
cprperformance is offline
Old 01-14-2021 | 09:19 AM
Rookie's Avatar
All boats are susceptible to that type of rot. One of my boats is is currently getting a new transom and partial stringer replacement. Not the one I thought would be rotted though. If you're concerned I have bought a pinless moisture meter from Home Depot and it did correlate good and bad readings that were consistent from a professional survey. If you find uncomfortable spots you could negotiate from there. Unless you are already buying it right.
https://www.homedepot.com/p/General-...-MM9/303124004
Rookie is offline
Old 01-14-2021 | 09:30 AM
I was thinking about finding a home depot and seeing if they had anything in stock. Did that meter work pretty good?
Old 01-14-2021 | 09:43 AM
On my way to home depot!
Old 01-14-2021 | 09:44 AM
Rookie's Avatar
It correlated pretty good. Some spots near exhaust and drain plug measured 15-21% and in the middle of the transom measured 8%. There was a discernable difference. Drill holes confirmed.
I would be looking for differences.
Rookie is offline
Old 01-14-2021 | 12:00 PM
Just picked one up, heading back to the boat. Thanks for the help!
Old 01-14-2021 | 02:22 PM
Just got done with my inspection. Turns out transom and stringers are gone! Unfortunate because I really liked the way the boat ran and handled.
Old 01-14-2021 | 02:26 PM
F-2 Speedy's Avatar
unfortunate, long trip for a soggy boat, what was the owners reaction
F-2 Speedy is offline
Old 01-14-2021 | 02:53 PM
Is the boat “take it easy”?
flat rate is offline
Old 01-14-2021 | 02:54 PM
Rookie's Avatar
When I bought my boat that needed the transom the owner and I split the difference on the price of a transom. He deducted it from the price.
Rookie is offline
