Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Replace stringers or fill with Seacast? >
Old 01-18-2021 | 02:33 PM
Default Replace stringers or fill with Seacast?
I have an old Donzi center console that has delamination of the stringers. It looks like (ll) when you look at them. I am going to completely redo the boat and want to know thoughts on filling stringers with Seacast.
Thanks for the help
Camarokidlt is offline
Old 01-18-2021 | 02:38 PM
Great stuff! I used it to fix my stringers in my houseboat. Solid repair that will never rot.
260cat is offline
Old 01-18-2021 | 03:46 PM
I assume that you got all of the wood out and then Seacast the stringers is that correct?
Old 01-18-2021 | 07:53 PM
Yes. I cut the top off, dug out all the wood, cleaned then filled with Seacast. Capped top of stringer off with fiberglass over the Seacast.
260cat is offline
Old 01-19-2021 | 07:08 AM
madbouyz's Avatar
Oy , by any chance is that a St Tropez you have ?
madbouyz is offline
Old 01-19-2021 | 08:06 AM
No. Its a 50ft Gibson houseboat
260cat is offline
Old 01-19-2021 | 05:02 PM
madbouyz's Avatar
That question was directed to the OP
madbouyz is offline
Old 01-19-2021 | 07:06 PM
It is not, it is a 26' center console with a swim platform and an outboard.
Old 04-25-2021 | 08:38 PM
Can engine mount lag bolts be screwed into Seacast and will they hold?
Tractionless is offline
Old 04-25-2021 | 09:42 PM
Really depends on what boat and if you drive like grandpa's pontoon boat or Bobby Sacentti's Apache....
phragle is offline
