Go Back  Offshoreonly.com > General Discussion > Offshoreonly Industry News
Livorsi Marine - Stepped Trim Tabs >
Old 02-02-2021 | 11:31 AM
Administrators
Commercial Members
Default Livorsi Marine - Stepped Trim Tabs
  • Reduces drag and increases efficiency
  • Provides increased fuel economy & performance
  • Stepped bottom design allows tab to release and re-enter the water stream faster for performance based applications
CLICK TO WATCH FULL STEPPED TAB VIDEO BELOW!
Stepped Bottom Hulls have been around for decades and have proven that the stepped hull design increases speed, reduces drag and increases overall efficiency. That is exactly what you get when you install Livorsi 1050/1150 trim tabs. Standard, non-stepped tab designs stick to the water, reducing speed, performance, and efficiency. Livorsi stepped tabs introduce air via a number of different grooves, channels and steps, reducing that stickiness and making the tab faster and more efficient. These tabs perform flawlessly in all sea conditions and can make your boat more fuel efficient compared to a non-stepped tab. For performance based applications, the stepped design allows the tab to release from the water stream faster, reducing drag and providing an overall faster boat. Why not take advantage of increased performance and efficiency?
INCREASED AERATION OF THE TAB SURFACE
  • Billet aluminum & Mil Spec hard anodized versus cast aluminum and painted
  • All running plates are easily interchangeable (750, 850, 950, 1050, 1100, and 1150), allowing quick determination of the 'Correct' running plate for the boat being designed or retrofitted
  • Available in 10 different colors
  • Electronic senders compatible with Mercury Vessel View, Livorsi Indicator, or NMEA2000 Device
Click here to view our catalog
If you would like to place an order please
Email: [email protected]
OR
Call: 847-752-2700
Links
IBJoel is offline
HTML code is On
