Possible gen v 502 rebuild? >
Old 02-15-2021 | 06:39 PM
Default Possible gen v 502 rebuild?
Since this is my first experience with a 502, I thought I would get some input from the experts on here. Had a mis fortune last year with a 502MPI, severely damaged the crank, 2 rods and 2 pistons. The block was bored .030, had all sorts of performance goodies. My question is , will the 502 block usually handle a .060" overbore? I will have it sonic tested before the rebuild, but that costs 100.00. I will not bother if the general consensus is that .030 is usually about the max. Since I will need a new crank, full set of rods, and pistons plus all the machine work, bearings, seals and rings, every dollar spent pushes the decision toward a complete shortblock alternative. I should mention that there is some slight scoring in 2 cylinders, and since I would be fitting new pistons, that is why I would need the overbore. I would rather do the rebuild, since I can control clearances, ring and bearing manufacture and the balance of the components.
Shotgunn is offline
Old 02-16-2021 | 09:32 AM
Will another 0.010 clean it up? 0.040 should be good
Cory H is offline
Old 02-16-2021 | 11:57 AM
the scoring appears deeper than .005", but it is tough to tell. The other issue with .040 over pistons is that the ones I need would have to be custom made and would cost nearly twice as much as the "on hand " pistons. Since I need a new crank, a 4.250" is the same price. 4.500" pistons are .030" over in a 502, but are standard bore in a 540. 4.530" pistons, and 4.560" pistons for a 540 stroke are very common. 4.540" not so much. I am seeking JE/SRP, Arias, or even wiesco pistons in 10-1 to 10.3-1 CR in the 4.250" stroke with 6.385" rods. Need to keep the crank, rods and pistons under 3000.00 or I might as well just buy a 540 shortblock. Also the "kits" I have seen do not offer a 4.540" option. I wonder if anyone has used the "kits" in a marine app. with success. They appear to use lower end components, but come balanced(so there is that savings too).
Shotgunn is offline
Old 02-16-2021 | 12:51 PM
Can you just sleve the 2 suspect bores?
carnutsx2 is offline
Old 02-16-2021 | 02:16 PM
That block should be fine to 4.600. I would take it to 4.530 and call it done.
snapmorgan is offline
Old 02-16-2021 | 02:56 PM
unknown, but I am sure it would push the budget to the 540 shortblock.
Shotgunn is offline
Old 02-16-2021 | 02:57 PM
This is an answer I am hoping to see more of lol
Shotgunn is offline
Old 02-17-2021 | 08:37 PM
That block will easily go 4.600. Nothing to worry about.
Smitty275 is offline
Old 02-17-2021 | 09:55 PM
To answer your cost question Scat 6.385 rods with ARP bolts $376 , Eagle 4.25" stroke crank, forged , one piece rear main seal $776, balance job $200, block machine work $600-700. I'm waiting to hear from the machinist for what size pistons I need bit SRP 4032 forged pistons are $598,, rings $121 , bearings $126, short block $2897. I need to add cleaning , deck and line hone , head work cam kit , gaskets , valves , timing chain , oil pump and maybe rocker arms.
Old 02-18-2021 | 06:22 AM
That is pretty close to my figures, cept my machine work is gonna be around 1500(including balancing), and I want to go with a total seal ring set(220$). Just under 4000 OTD vs a Dart shortblock at around 5500delivered. I have a 741 cam, but honestly, I was not that impressed with it in the last engine and may choose something else. I did install it 2 degrees advanced and maybe that cost me some power. The high lift would have ate valve springs if the engine would have lasted long enough. I am not gonna chase MPH this go round, and want dependability, and longevity over the extra 3-5mph. Plus I have a brand new(well 8hrs now) Xdrive and really dont want to stress it too much.
Shotgunn is offline
