Go Back  Offshoreonly.com > Technical > Electronics
Might be a stupid NMEA question >
Old 02-18-2021 | 01:28 PM
Default Might be a stupid NMEA question
So I’m installing a fusion head unit. I would like to connect it to my Garmin screen. My Garmin has nothing else running to it so do I need to build the backbone or can I plug it directly into the screen? Thanks
SNSTER is offline
Old 02-18-2021 | 07:16 PM
You need to build a backbone with power, and termination resistors
Unlimited jd is offline
Old 02-19-2021 | 01:00 PM
Unlimited's comment is correct. Powered backbone then drop cables from each device to backbone.
ALL_IN! is offline
Old 02-20-2021 | 11:58 PM
Jim Diesel's Avatar
"Unregistered Gun"
What they said and just like this, connect your device to the drop and your ready to go. I powered my backbone from my GPS power switch.
Jim Diesel is offline
Old 02-22-2021 | 01:41 PM
Thanks for the info. I’m curious how everybody supplies the power.
SNSTER is offline
Old 02-22-2021 | 02:17 PM
Amazon Amazon
ALL_IN! is offline
Old 02-23-2021 | 08:29 AM
When I did mine a few years ago, I purchased a backbone kit that had the termination resistors and power supply included. Make it simple and buy a complete kit, you ll be glad you did.
endeavor1 is offline
Old 02-23-2021 | 12:17 PM
This will be everything you need. All connectors, cables, power and terminator resistors needed for your particular install all in one package
Amazon Amazon
Chris
Blueabyss is offline
Old 02-23-2021 | 12:21 PM
it really depends on the system.
Old 02-23-2021 | 05:50 PM
I’m assuming it needs to be key on power and not just ran to the battery?
SNSTER is offline
