290SC or 280 Height on Trailer >
Old 02-22-2021 | 01:02 PM
Default 290SC or 280 Height on Trailer
What is the height on trailer of a 290SC or 280? Trying to determine if one would fit in a standard height garage, I've got a detached garage that's 40X30ft, but door height is only about 6ft 10in.
TexomaPowerboater is offline
Old 02-22-2021 | 02:21 PM
GRH
It would depend to some degree what trailer it's on?
GRH is offline
Old 02-22-2021 | 11:10 PM
My 260 on an ameritrail trailer just clears my 8 ft overhead door.
My boat has the bigger windshield on it and 14" tires on the trailer.
I don't think 6" 10" is going to cut it. unless it doesn't have a windshield.
Revd Up is offline
Old 03-04-2021 | 02:39 PM
Thanks for posting. I can do without a windshield. There is a nice 30ft Velocity single engine for sale that seems low enough on a trailer to fit a standard height garage, which caused me to post this thread. https://www.boattrader.com/boat/2006...y-vr1-7632167/
I'm also curious if any of these bigger single engine velocity's like the 260, 280, or 30 struggle to get on plane with a boat full of people like some of the 29 fountain single engine boats I've read about.
Old 03-04-2021 | 03:07 PM
I have a 280 with stock 496ho, have no issue with getting on plane with passengers.
underpsi68 is offline
Old 03-04-2021 | 10:13 PM
That is a nice looking boat!
With 800 hp it should get on plane just fine.
Revd Up is offline
Old 03-06-2021 | 03:26 PM
Revelocity's Avatar
The VR-1 uses the same hull as the 290 so 30' is a listing error. The drive height and prop configuration greatly influence how well it planes off. I suspect this boat was set up for top end with a high x dimension that needs a 5 blade prop. The good news is that you can lower the drive to make it plane off better or perhaps just use a prop with more blade area.
Revelocity is offline
Old 03-11-2021 | 07:52 PM
290 SC 7' 7" tall.. here is going in an 8 foot door...
Boatally Insane is offline
Old 03-12-2021 | 12:41 PM
Awesome, thanks for posting. How much height does the windshield add? Does the trailer use a torsion axle?
Old 03-12-2021 | 04:34 PM
If you are still looking at a VR 1 it will be lower then a 280 or 290.
Padraig
Padraig is offline
