Merlin 509 SB / 454 Gen VI LB ..MD
Early Spring Cleaning Located MD 21085. Can Crate and Ship if Needed. 443.518.zero.seven.88
- Just cover Shipping and Paypal Fees Please if using paypal. Open to other options as some have preferences. Thank you.
-Tried to get pics in order. Any questions please ask.
Engine 1
- (PENDING) Merlin II Block. 4.500" Bore....$1500 ( Currently at the Machine shop getting cleaned and prepped for assembly and taking care of Cam boss issue-See pics ) max bore Officially 4.560 " Unofficially is 4.625" Will clear 4.250" Stroke Brass Freeze Plugs.
-4.500" Rotating Assembly..... $600 ( Manley Rods 6.385 / Pistons 1.395 CH ( 96.5cc-10.5:1 / 115cc-9.1:1 / 119cc-8.9:1 ) Pistons are used. Extremely low Run time. Currently no Rings
- ***( Option )*** Merlin with Rotating assembly as assembled short block.....$2600 Rings can be gapped to your preference with Ring manufacturer of Choice.
Engine 2
-*** ( Option 1 ) *** Assembled Long Block 454 Gen IV Fresh Rebuild. Running on Stand ready for your accessories, ( Valve Covers/Flame Arrestor not included. ....$5300 with New Lifters, $4800 with Used Lifters With Merc Dist.
-HP500 Carb
-Merlin Rec. Port Marine Intake with Brass inserts
-Merlin I-043-c heads. Fresh Valve job and Springs set for Cam Specs.
- *** Reusing lifters as they were in good shape. Can opt for new ones if necessary.
-HP500 Crane 731 Cam 284*/292* @ .004"
222*/230* @ .050"
.576"/.598" valve
110* LSA
105* ICL
115* ECL
- SRP with small dome. 9.5:1 CR
- Factory rods and GM Steel Crank
-Marine oil pan
-Comes with Starter
-***( Option 2 ) 454 Long block Assembled as it sits Carb to pan no run time ( No valve Covers) / ( No Flame Arrestor ) ... $4300 with used Lifters / $4700 with new Lifters GM 12371056
Engine 1
Engine 2
-HP500 Carb
222*/230* @ .050"
.576"/.598" valve
110* LSA
105* ICL
115* ECL
-Marine oil pan
-Comes with Starter
