BBC head studs >
BBC head studs
BBC head studs
Old 03-08-2021 | 10:04 AM
Default BBC head studs
Installing a set of head studs and there is a lot of different ideas on stud nut torque specs especially with aluminum heads. ARP says 80flbs seems a bit much. some say as low as 65flbs...
454 blower motors with about 6 lbs of boost. Some of the threads say around 70-75flbs. any input would be greatly appreciated...
offshoreratboy is offline
Old 03-08-2021 | 10:37 AM
Rookie's Avatar
All depends on the material of the stud. Go with manufacturer specs on the studs you buy. (it's the elongation of elasticity of the given material that the stud is made from that is important)
Rookie is offline
Old 03-08-2021 | 12:35 PM
Originally Posted by offshoreratboy
ARP says 80flbs
Why would you not do what the stud manufacturer says ??
BillK is offline
Old 03-08-2021 | 01:41 PM
ARP says 80 then do 80. Unless you know something they don`t .
I`ve always done 80 with my ARP head bolts .
ICDEDPPL is offline
Old 03-08-2021 | 04:49 PM
SB
All good answers. ^^^
Do it the Canadian way. Yes, a few Canadians told me this.
Tighten it till it breaks, then back it off a touch. :wink
SB is offline
Old 03-09-2021 | 07:15 AM
ARP says 80FLBS less with aluminum heads. How much less?
Old 03-09-2021 | 07:56 AM
I torque mine to 75# with ARP lube. Aluminum heads.
fbc25el is offline
Old 03-09-2021 | 08:54 AM
SB
Yup, Most say 70-75 max with arp lube aluminum heads.
SB is offline
Old 03-09-2021 | 09:00 AM
do indeed use the Arp thread lube we just installed new Arp studs in a dart block with big cheif heads and torqued to 80 with a mls gasket
boostbros is offline
Old 03-09-2021 | 10:46 AM
I always lightly lube both matting surfaces also. Torque again after a little run time.
getrdunn is offline
