HP 500 valve spring specs
I have twin HP 500's in my 1998 32' Fountain Fever with 550 engine hours. The dealer says that the engine has never been opened. I want to replace the valve springs. What should I get? I'm looking for dependability/durability, not necessarily a performance boost. Also, while my Tech is at it, is there anything else I should tell him to look for?
I’d do the whole top end...the engine is open for surgery; might as well replace everything. Otherwise when do you expect to open it up again another 300 hours. I’d be leary of having 800 hours on rockers, etc.
id replace springs, locks, gaskets, rockers, lifters, push rods, seals, valve job, etc.
good luck.
good luck.
