Aftermarket drain plug >
Old 03-19-2021 | 02:48 AM
Default Aftermarket drain plug
Who makes the hex head drain plug for a bravo 1 that you can use a socket on? I've seen them before but forgot where.
Barr Hopping is offline
Old 03-19-2021 | 03:18 AM
bencini231's Avatar
Imco has them, that's where I get mine from. https://imcomarine.com/cal_store/drain-screw.html
bencini231 is offline
Old 03-19-2021 | 08:41 AM
SB
As a related note, if people would like a better fitting screwdriver for their normal drain plugs, these Snap On outdrive plug screwdrivers work well until someone doesn’t return it. Doh ! Also, real large headed screw drivers work well too.
https://shop.snapon.com/categories/M...drivers/760266
SB is offline
Old 03-19-2021 | 09:21 AM
Rookie's Avatar
Edit, wrong drain. lol
Rookie is offline
Old 03-19-2021 | 10:28 AM
Call Craig Colabella Performance in Fl probably got em the top tray of his toolbox ... He's a great guy and Honest as the day in Loooong
PROP STAR is offline
Old 03-20-2021 | 06:57 AM
I have one of these. They do work well. Wanted to mention that if you look at this picture, where the metal meets the handle, there is also a place to slide a wrench on to help turn it if the screw is really tight. I believe it’s a 7/16 inch wrench. Thanks for posting.
tgorbett is offline
Old 03-20-2021 | 09:20 AM
Thumbs up
Thanx SB , I been looking for a screw driver like that for a while.
Found a amazon version too.
Amazon Amazon
ICDEDPPL is offline
Old 03-20-2021 | 10:15 AM
I never could figure out wht they use a slotted drain plug.
Padraig
Padraig is online now
Old 03-20-2021 | 10:24 AM
Padraig
hydrodynamic superior when the slot is aligned with the water flow (LOL)... seriously through, with the right tool, and the Snap on driver works great (* there are two bit widths available so get the right one), fresh gaskets - you don't need to pound the plug on to create a proper seal. The slot works well for what it is meant to do + the surface area of the slot provides good bite for the proper tool (you can fk up any fitting with bastardized tools forced to make do)
speicher lane is offline
Old 03-22-2021 | 10:22 AM
Merc uses a slotted plug so morons don't put a ratchet on it and tighten it to high heaven and strip it out. You can get it plenty tight with the slotted head. I've never had a problem getting one out.
Smitty275 is offline
