MPI to carb distributor question >
Old 03-24-2021 | 08:37 AM
onesickpantera's Avatar
Default MPI to carb distributor question
Thinking about swapping from MPI(1996 502 Mag with cool fuel) to carb and I see conflicting answers on the distributor. Some say the current distributor won't work, and others say it will as there is a module in the distributor that will advance the time a set amount. Anyone know for sure?
onesickpantera is offline
Old 03-24-2021 | 08:55 AM
SB
Yes, i know for sure. In person too. It has advance. Starts and ends quick.
This is the same as the EST system and Delco Voyager system used on many carb’d systems - new and retrofit..
SB is online now
Old 03-24-2021 | 09:14 AM
SB
For it’s “timing curve’ See page 12 of pdf which is page 64 of the document.
https://f01.justanswer.com/oldneweng..._Delco+EST.pdf
Clearly shows why some think there is no advance.
SB is online now
I saw a few of your comments when I did my 712 searches.
How do you know the amount of advance? Or do you have to put a timing light on it to find out?
Old 03-24-2021 | 09:17 AM
Just saw your second post. I will check it out.
Old 03-24-2021 | 12:43 PM
If it's MPI isn't the timing advance controlled in the ECM?
liberator221 is offline
Old 03-24-2021 | 12:58 PM
SB
When it’s controlled by the computer.
SB is online now
Old 03-24-2021 | 03:28 PM
SB- so that dist is just a hall effect switch with no centrifical advance and he will have to switch dist won't he? Delco system on non EFI advance is built into the ignition module that is in dist. EFI advance is controlled only through ECM
I,m not positive just asking.
Old 03-24-2021 | 04:36 PM
SB
Magnetic pickup.
Module controls dwell (very well i may add. Lots ‘o spark )
also has an advance curve in it in case not used for EFI. Very quick curve. Starts heavily at 600rpm. See thise pdf pages i noted above.
GM for the win.
SB is online now
Old 03-24-2021 | 06:07 PM
If you are switching over , keep in mind it’s age.
smokediver is offline
