Replacement for 088 heads ? >
Old 03-30-2021 | 06:43 PM
Default Replacement for 088 heads ?
Hey guys,
I am rebuilding a 454 MPI engine and need to replace the 088 heads. Looks like some guys have had issues with the Enginequest heads so that leaves me with World Products or a GM performance part head. The World heads are cut for 2.300 valves and I am not sure about that in a 454. The GM heads (12562925) are cut for 2.18 intakes but that is not a big deal to open them to 2.19" The engine has been redone before and is not stock but has been running great for about 400 hours. It burned up a piston due to a bad injector. I want to try to keep the combination as close as possible.
I think I have talked myself into the GM head but just figured I would see if there were any other opinions.
Thanks,
Bill
BillK is offline
Old 03-30-2021 | 07:26 PM
GPM
Maybe look at the Dart Iron Eagle
GPM is offline
Old 03-30-2021 | 07:41 PM
I have only read two bad reports on the EQ heads. One the guy had valve guide angle issues (allegedly), the other actually ran them for some hours and said the valve seats were “soft”.
what info are you referring to?
sailtexas186548 is offline
Old 03-30-2021 | 07:55 PM
I have AK racing aluminum heads and quite happy with them.
phragle is offline
Old 03-30-2021 | 08:05 PM
Default AK Racing
I can help.. feel free to call Al 905 252 0592
adk61 is offline
Old 03-30-2021 | 08:42 PM
I have new world products grumpy jenkins heads. I have the ovals 269s and rectangular ports in 320 and 345.
outlaw26 is offline
Old 03-30-2021 | 08:48 PM
A couple of threads here and also one of my friends at another machine shop had a set and said that the guides and seats were finished terribly. I am also a little leery of the 2.300 valves.
BillK is offline
Old 03-30-2021 | 08:51 PM
I can get the World heads direct myself. I dint think they were still making the Grump heads ?? Will they work on a Gen6 block ?
BillK is offline
Old 03-30-2021 | 08:53 PM
Dont want Aluminum. Like I said I dont want to change this combination any more than absolutely necessary.
BillK is offline
Old 03-30-2021 | 08:59 PM
They have a raised exhaust port.
BillK is offline
