AFR heads and CMI's - Gaskets? >
Old 04-01-2021 | 07:00 PM
TomZ's Avatar
Default AFR heads and CMI's - Gaskets?
I ran a FelPro 1411 with my iron heads. Any reason not to with the AFR's?
TomZ is offline
Old 04-02-2021 | 03:43 AM
I wouldn't even consider a composite type gasket between an iron block and an aluminum head. You'd be much better off spending the money for Cometic gaskets. Plus if it ever has to come apart again you can reuse the Cometics several times with a light spray of copper coat.
Smitty275 is offline
Old 04-02-2021 | 08:03 AM
SB
Looks like the AFR’s re only 3$ more than the Felpro’s.
https://www.summitracing.com/search/...t-in/2-130-in?
SB is offline
Old 04-02-2021 | 08:47 AM
TomZ's Avatar
Probably an obvious answer. I had a big order being put together at Jegs and AFR’s gasket wasn’t available.
TomZ is offline
Old 04-02-2021 | 09:12 AM
SB
A Possible issue with those felpro gaskets is port size. They are listed as much smaller than the afr’s. You do not want any gasket material overlapping into the exhaust port of the cylinder heads.
If they don’t, then run’m
SB is offline
Old 04-02-2021 | 09:13 AM
SB
He was asking about exhaust gaskets.
SB is offline
Old 04-02-2021 | 09:35 AM
TomZ's Avatar
I might have a single gasket up in the boat. I’ll need to look at it. Probably just easier to get the right gasket from AFR.
TomZ is offline
Old 04-03-2021 | 08:34 AM
1412 are the big oval gaskets
benjen is offline
Old 04-03-2021 | 09:08 AM
1411 felpro works for me . AFR 315 heads & CMI E tops.
fbc25el is offline
F-2 Speedy's Avatar
Call Edie Young, he has a multi layer gasket is is reusable. I ran them on the Merc racing heads and the AFR
F-2 Speedy is offline
