Question formula fastech 312 2001 6.2L >
Old 04-05-2021 | 04:32 AM
Default Question formula fastech 312 2001 6.2L
Hello everyone, I have just purchased a formula 312 2001 with 2x6.2mx engines, I want to change the engines for 2x454 mag I am wondering if someone has already done it? the holes for the exhaust arrive at the same position in the transom? do the engine mounts need to be changed? and my ration is 1.65 which pitch should I go 30? thank you for your answer and help
285ssi is offline
Old 04-05-2021 | 07:13 AM
The boat doesn't have enough width to install BB, only 8' 3"
AllDodge is offline
Old 04-05-2021 | 07:17 AM
the boat left the factory with either 2x6.2 2x454 and 2x502 I do not understand that you say that
285ssi is offline
Old 04-05-2021 | 07:57 AM
Yea, I think I've seen 312s for sale with 502s or 496s Seems like a big jump from a 350 or 377.
I just replaced the 350s in mine last winter, not much fun, but I'll follow along here for pics
SabrToothSqrl is offline
Old 04-05-2021 | 08:53 AM
t500hps's Avatar
21 and 42 footers
Wrong. Very few 312's built with small blocks. My 98 312 came with 502 mags. 454 MAGS with 1.65 came with 30's (502's did also). Boat should run LOW 70's with 454 MAGS. If you're considering regular 454's don't bother with the switch. I have no idea about engine mounts/exhaust lining up, etc.
t500hps is offline
Old 04-05-2021 | 10:46 AM
Sell it and buy my 2003 with 496HO in it!
MNHeat is offline
Old 04-05-2021 | 11:32 AM
no no I'm going to put 454 mags or 502 I was looking to find out if someone had already done the swap to know if the exhaust arrived at the same height etc
285ssi is offline
Old 04-05-2021 | 03:51 PM
https://www.hardin-marine.com/Instru..._Locations.pdf
Unfortunately the locations are not the same, but it is pretty easy to move them. You will have to do a little glass work and gel.
ph1971 is offline
Old 04-05-2021 | 04:29 PM
yes I understand what you are saying but take a good look at the 2 pictures the exhaust belows on a quite distinct angle
285ssi is offline
Old 04-05-2021 | 06:14 PM
I didn’t realize you were going to run cast manifolds and risers. With that hose length you will be fine at sb locations. The motor mounts are probably a different story but I don’t know off hand. My factory big block boat left Formula with sbc exhaust spacing. It wasn’t an issue until I put on aftermarket exhaust that damn near touches the thru hulls.
ph1971 is offline
