Pdm
Old 04-14-2021 | 09:25 PM
Default Pdm
Looking at options for rewiring my boat and was thinking of going with the same thing I used for my car which is a solid state pdm and keypad. Has anyone else done this in their boat?
Big_Baller is offline
Old 10-29-2021 | 08:12 PM
Figured I would close the loop on this... I went with a Moristech P30 PDM for my power distribution module which allowed me to program the outputs, and use a CAN keypad. The wiring harness is all milspec wire, mostly 14awg with Deutsch connectors.
Old 11-01-2021 | 08:16 PM
Cool set up. Never thought of using one of those in a boat. I'll definitely consider one for future projects.
waveryd is offline
Old 11-04-2021 | 08:42 PM
Yeah it makes wiring so much easier, it can be as simple as inputs trigger outputs, or you can layer on functions like setting a timer for the blower fans before you start the engine.
Old 01-07-2022 | 02:53 PM
Big Baller -- What are your thoughts on the NMEA2K SSR systems? You can run everything from your Garmin or aftermarket EFI PCM. I am thinking of rigging a boat like this currently. Nice part is you can set overloads, trip resets, bundle together for large Amp loads. By running a Nmea2k cable into the engine compartment you could control all the electrical loads...
delsol is offline
Old 01-08-2022 | 07:39 AM
Looks like it is another flavor of CAN so i assume it will work just as good. I went with AEM Net / moristech pdm because i used both on my automotive projects with great success. A single CAN keypad means i control all power function on the boat via 4 wires and all signals for gauges (digital dash) are sent to front of boat via 2wires.
