Mercury 565 Actual HP?
Old 04-16-2021 | 05:32 PM
Default Mercury 565 Actual HP?
Has anyone dyno'd a Mercury Racing 565? Anyone know what the actual HP is close to? A 525 usually dynos closer to 540 so just wondering if the 565 is also under-rated.
thirdchildhood is offline
Old 04-16-2021 | 06:06 PM
sub'd
Eddienel is offline
Old 04-16-2021 | 09:26 PM
I've got a dyno someone just needs to bring a 565
Andrew56 is offline
Old 04-17-2021 | 07:25 AM
Not under rated, just measured at the prop.
Don't know the number, but it would be higher at the flywheel
AllDodge is offline
Old 04-17-2021 | 07:29 AM
So the 525 and the new 565 are both measured at the prop?
I'm seeing speed increase claims much higher than I'd expect with only 40 more hp.
Old 04-17-2021 | 08:21 AM
Yes, change to the prop (NMMA - National Marine Manufactures Assocation) was done years ago. As example, manual 23 for a 502 MPI the MCM list 415hp and the MIE list 400hp
Don't know about the claims
AllDodge is offline
Old 04-17-2021 | 08:38 AM
Rookie's Avatar
It says 565HP crankshaft rated.
https://mercuryracing-prod.azurewebs...engines/565-2/
Rookie is offline
Old 04-17-2021 | 09:04 AM
Originally Posted by Rookie
Is that the front of the crank or the back?(joking) Whatever it is I want one!
Eddienel is offline
Old 04-17-2021 | 09:10 AM
OK, wonder what the manual list the hp is, because that would be with drive?
The 6.2 MPI list 350 hp as a bobtail, in a boat Merc list as 320hp in manual 31
AllDodge is offline
Old 04-17-2021 | 11:24 AM
Yep, it sure does. I looked in my 525 service manual and it also says 525 hp rated at crankshaft. Hmmm.
