28 Skater bilge pump >
Old 04-17-2021 | 07:50 AM
Default 28 Skater bilge pump
Does anyone know what make/model of bilge pump this is?
The black cylinder is the float for the float switch, so clearly that needs to be fixed, but neither of my bilge pumps operates even when manually switched on. So I may need a pair of new ones.
And yes, it is dirty. Everything is covered in something that seems to be a mix of black mould, kelp fragments and Evinrude oil.
Bilge pump for 28 Skater__PRESENT
Markus is offline
Old 04-17-2021 | 08:48 AM
The switch is a ultra. Not sure on the pump but a rule would work
flat rate is offline
Old 04-17-2021 | 09:54 AM
Thanks!
The switch is indeed an Ultra Junior.
Compared to the price of an Ultra switch, a Rule pump seems like a bargain...__PRESENT
Markus is offline
Old 04-18-2021 | 04:50 AM
The pumps are Mayfair Durapump 2200 gph, which seem to have been superseded by a Johnson Pump product that is red instead of yellow.
Whether those pumps came stock from Douglas Marine or are replacements for something else, I don't know. In addition to the Ultra Juniors that are attached to the pumps, there is another set of switches that is left in place but disconnected.
So at a minimum, switches have been replaced. Maybe pumps, too.
__PRESENT
Markus is offline
