700SCI Stalling Around Dock >
Old 04-21-2021 | 09:11 PM
Default 700SCI Stalling Around Dock
Recently purchased an Outerlimits with 700SCI and SSM6s. Boat has 200 hours and runs great. However, around docks in gear I will randomly have an engine stall. No alarms, just cuts off in gear. I then have to try and get it out of gear to crank and restart, which it does immediately. Anyone else have this issue? It’s tough to start blindly trying to figure this out.
Jpzaluski is offline
Old 04-22-2021 | 05:34 AM
Pressure check the headers. One tube or more is leaking causing the motor to stall at idle in gear.
Kevin Schulte is offline
Old 04-22-2021 | 07:55 AM
F-2 Speedy's Avatar
Get a scanner on it and watch the IAC
F-2 Speedy is offline
Old 04-22-2021 | 07:56 AM
Ditto IAC.
1MOSES1 is offline
Old 04-22-2021 | 08:10 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
JZ, did you buy the boat that JW had?
IACs can and do go bad without throwing a code. It's a cheap replacement to try to rule it out. Beyond that, take Kevin's advice and check the headers.
Sydwayz is offline
Old 04-22-2021 | 08:11 AM
I would swap IAC's. Two bolts and a plug. Takes 5 minutes. Had that issue with my 700's in a past boat.
McKay is offline
Old 04-22-2021 | 08:12 AM
VoodooRob's Avatar
IAC great advice, also the headers could be the start of a problem always good to check them out. I would also look at your fuel system. Have you changed the small fuel filter on the rail and the fuel separator spin on? Injectors flowed, cleaned, and rebuilt? Also these ECMs are getting old and could be getting beat on with an IAC that is trigger happy. Do you have the over current protection Merc kit recommended from their tsb? Run your engine serial #s in the database to check what's been done in that regards. Also a Rinda handheld scan tool is invaluable with these engines, it will help to sharpen your focus on issues. edited Almost forget also check your coils with the scan tool, like the ecm they are getting old
VoodooRob is offline
Old 04-22-2021 | 12:30 PM
I’ll certainly check after some other things, however it has brand new (few month old) stainless marine manifolds and risers on it.
What’s up Brian.... I bought the all white 39 GTX that was on the eastern shore.
Old 04-22-2021 | 12:33 PM
Rob, I’m gonna pull the IACs and clean them. Previous owner had replaced both last season and it also does have the inline fuses for the IAC. Eddie told me to make sure the IAC had enough travel to be able to save the boat when put in gear, meaning if the throttle blade was too closed and relying to heavily on IAC air to idle in neutral, that it didn’t have the travel to give it all the air it needed in gear.
Also, I was looking at some software for a laptop of a scanner. Is Rinda full function? Which one do you recommend?
